Windshield Wipers
Shawn F.
Windshield Wipers
Post by Shawn F. »
I bought new wipers for my 66 F100 from NPD locally but find that they do NOT make contact with the windshield. They are the correct stainless style ones and I even tried bending them but still no luck. The original ones (previous ones) hit perfect and fine but these dont even touch in most areas. There are a few spots where about 2 inches touch all the way along it's path but that's it, not enough to see good enough to drive in the rain.
Any reason why this is or what I should do about it? I like the stainless original look so would like to make these work. I tried bending them but that doesn't help.
If anyone else has had this problem and has a solution to fixing it, I would greatly appreciate any help!
Fordman
Post by Fordman »
if you mean the rubber isnt touching completely that is the problem with the newer rubber in them probably. you may try a better rubber in the holders.
Shawn F.
Post by Shawn F. »
Can you just replace the rubber and that's it? If so then does Auto Zone or NAPA carry these? I really need to get this problem fixed since it almost caused me to wreck when I first got them and it rained...[/code]
Effie
Post by Effie »
I've never found just the rubber refills...well, lemme take that back...I found some at one of the better parts store, but they were too long.
Just Rain-X it real good...I haven't put the wipers back on my '66 yet. :lol: But I don't drive it in the rain either. :?
So did you buy the arms and the blades from NPD or did you just buy new blades? I bought mine from Dennis Carpenter and they worked fine. Call NPD and see what they say about it.
~/\/\elissa~
Image '66 F100 -- Little Black
Image '78 Bronco -- Brutus
Lowell
Post by Lowell »
You didnt say whether you bought new arms . The rubber on mine doesnt touch the glass like it should , i think the springs in the old arms have gotten weak after 44 years. been aiming to order new ones.
Fordman
Post by Fordman »
what are the rubber abotu 15 inches long. i have gotten replacements at wallyworld. but those are junk also. try the local parts store. if you have to cut one end off its not that hard to do really. as long as you cut off the end that doesnt clip it into place.
been buying 15" wiper blades from the auto parts for years.never had any problems with them.
there are aftermarket springs i have seen that go over the arm that keep tension on the windshield. i have a set i found but never put them on anything to try them.
07mike
Post by 07mike »
I bought new wiper arms and blades from Mac's and they work and fit perfectly.They were the only parts that I didn't have to modify when doing my 66 shortbed
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
here is the story and see it time after time on 61/66 trucks and these big companies DO NOT DO IT AND Not to brag BUT we do,,, There is one MFG. makes them suppose to fit well wrong,,, They have to be bent the arms and just saw on a 25000 dollar truck here on the site a few days ago they where bent in all directions, reason they where bought from one of these big companies < will not say since so many think are great > and when they get them in reality do not know anything about them , well when we get them in I have to bend them the right way so they will fit for 61/66 trucks cause straight from the MFG the S/S arms and blades WILL NOT FIT 61/66 Trucks
12649
Shawn F.
Post by Shawn F. »
I did not get new arms, just the blades in stainless. I want the stainless still. The arms and springs seem to be just fine and the old blades worked just fine. I changed the old blades because they were beginning to rip apart even thought they still barely worked. It seems the arc in the new ones just dont contour to the windshield at all. I tried pushing down on the arm for more pressure and that still doesn't help, it's the shape of them. I got them from NPD and got just the blade in stainless just to repeat.
