windsors in straight axle trucks.
- ezernut9mm
anyone got any pics? especially of the engine mounts. i am trying to figure out what i need to do here to mount mine up.
I can make you patterns of my towers Chris.
Use a double hump pan and good to go - you shouldn't need to hack the crossmember for manifolds like I did for headers.
You know where my pics - I'll be happy to take anything else you need.
- ezernut9mm
greg, i have mounts, but am not really sure how they "bolt" to the frame. i have the engine mounts figured out, but i'm not sure on the "stands".
these are the style that lmc and others sell and are supposed to be a direct "bolt in".
Ah - got ya.
Post a pic of them?
Post a pic of them?
- ezernut9mm
yeah. tomorrow. lol. i am about done for the evening. gotta love those 100* temps we've been having.
Seriously miserable for sure.ezernut9mm wrote:yeah. tomorrow. lol. i am about done for the evening. gotta love those 100* temps we've been having.
- Johnny Canuck
I have these
http://www.spiderautomotive.com/transdapt4145.html
the top mounts bolt to the block in the two bolt holes shown.
the bottom mounts bolt to the frame in the bolt holes shown.
No rocket surgery required
- Alan Mclennan
I take it then!, a engine mount tube would hit the axle or drag link!.
I have the tube style and wanted it because it seemed the strongest aside from making your own. No clearance issues that I've come across. 351W/C6 in a '64.
Hopefully you can see how it's mounted in these pics:
- Alan Mclennan
very nice Max, I`d go with the tube type too!, as it takes the flex out of the chassis at the mounting points.
Nice looking job you've got going there Max. Do you have the column hooked up yet? My main concern with mounting the steering behind the axle like that is the amount of movement you get from the axle going up and down. I figured to mount one in front if I ever get around to trying it. I felt that you would not have to accomidate the travel so much on a slip joint. Moving the steering to the front side of the axle means the up and down movement can be be somewhat taken care of without so much travel in the slip joint. In addition, the steering works easier from the front side, in my opinion
- ezernut9mm
wow, that's purdy regilio. power rack and pinion?
here are the mounts i have and mr. kimbrel has helped answer some of my questions already.
Thanks Dimitri. Steering on mine isn't hooked up yet but with 2 u-joints it will have room for travel.
I mocked it up before I removed the cab from the frame and the only thing I was worried about at the time was putting a sealed bearing on the bottom of the steering column to keep everything in place now that the box is gone.
- 64 Thunderbolt
Max, keep us posted with steering pics! That looks AWESOME!
I'm still debating what front setup to go with. I started looking at the Crown Vic front setup last night. I was originally thinking about flipping the axle.
Either way I have a right nasty 306 for my 64, so this thread really interest me!
64 Thunderbolt Clone (in progress)
Henry J gasser
85 F350 Dually
95 Explorer
Henry J gasser
85 F350 Dually
95 Explorer
- Johnny Canuck
Those look similar to mine, Chris. looks like you are missing one frame mount.I had the luxury of being able to mount mine in the correct -for -Ford offset because i have gussets on the inside of the frame right there, from my Aerostar setup.
- ezernut9mm
i have both mounts john and the one pictured has a spacer plate welded in it for the offset. the other one does not have that spacer.
i have done some preliminary measuring and it looks like i might get away with only moving the fuel line which i would have to do anyways as the 302 has the fuel pump on the drivers side.
since my truck is a 4 speed truck i was wondering if the c-6 will fit under the factory removable hump? it does not seem to have the height clearance that the 65 and up trucks have.
- Alan Mclennan
ezer, what motor do you have at the moment?, and what are the mounts like?, any pic`s
- Johnny Canuck
Can't help you there Ezer I have an E4od on mine and had the removable hump from a tall tranny truck welded in my floorezernut9mm wrote:
- Alan Mclennan
Chris, can I just say I think you would be better off with an engine tube mount!, those other mount`s remind me of someone doing the splits!. JMHO!
