First off, thanks slick members for the help thus far.
I am finally starting my build thread to give something back to the forum (WARNING! this will be PIC heavy).
My new "old" 1966 F100 Camper Special
FE390
Dana rear end with posi track
Caribbean turquoise/Wimbledon white paint
First pic already tucked away (CRAMMED) into my garage
This morning I visited a buddy up at Pep Boys to mount and balance all four tires (grand total of $45.00).
Before you see the pic remember, I want the wheel color to match the truck.
We went through several samples and none matched even close to my paint.
I decided to go with white and I can live with this until it warms up and I can spray these babies an exact match to my Caribbean Turqouise.
One more up close...THANKS Tom for allowing me to tag along. I was in the way more than I helped. The whole process probably took twice as long just because of me!
It has been a busy couple of days. The relocation of the gas tank mod turned out to be a little more difficult than I imagined. Here she is:
No BALD jokes please!
Frame welded up
Ready for some hangers. Background 1970 Mustang 22gallon tank
Mounted up with some POR15 topcoat
Close up of the hanger
Sender and fuel line
Nice work! I really like the tank relocation. I should consider that when I have the bed off in the Spring. I miss having the extra room behind the seat.
How is the tank attached to the frame that you made?
BigMike wrote:Nice work! I really like the tank relocation. I should consider that when I have the bed off in the Spring. I miss having the extra room behind the seat.
Thanks BigMike, if you look closely at the pic of me welding the frame, you can see the tank lip on the right with pre drilled holes. I drilled some holes in the frame and used screws about 1/2" long.
It has been a few days now and everything is still solid. I did use some plastic spacers I between the hangers and the frame rail to eliminate any unwanted noise. OH, I HAVENT EVEN RUN OUT OF FUEL YET...22gallons YEAH!!!
I'm thinking of doing a tank relocation this winter as well... I've ready Uncle Skip's instructions on his method, but yours seems a little different.
Here are some questions I've got for you:
You just bolted your tank frame to the bottom of the truck frame?
Did you have to move any of the frame cross-members?
Is that 1" square tubing you used?
What thickness of metal did you make the tabs/brackets out of?
Did you weld the heads of the bolts to the topside of the frame/cross-member so they wouldn't turn? Or were you able to figure out a way to get a wrench in on them?
What did you use and where did you get the hardware for the filler neck and cap?
