FYI
Read this and I think it will be self explanatory. Yes, Mar-K sells the thread inserts.
http://www.mar-k.com/Thread_Insert_Install.pdf
Blind nuts in sheet metal
- Uncle Skip
Re: Blind nuts in sheet metal
Keenserts is another brand name which to me is more "user-friendly"
They are also removable in case of the inevitable screw-up
I have rivet-gun type as well. Been using them since my drag racing days. My lexan was held in my car by these with button-head stainless screws. I use them a lot in my slick, especially in the firewall and inner fenders.
FYI, Harbor Freight actually has the installer gun for these now. But don't use the inserts that come with it. I found the good steel ones on ebay CHEAP!
I used these inserts for my door panels. FYI the 1/4-20 inserts work great for this.
- 1965fordf100
[quote="sully5"]I have rivet-gun type as well. Been using them since my drag racing days. My lexan was held in my car by these with button-head stainless screws. I use them a lot in my slick, especially in the firewall and inner fenders.
Sully,
You say you use these on your firewall and inner fenders...did you use these for the hidden nuts for your hood hinges? And are you also using them in place of j-clips on your inner fenders?
Thanks,
Phil
Sully,
Thanks,
Phil
Phil
No, I don't use them for anything structural or high strength. I use them for attaching wiring clips and things like that. You can actually squeeze to installation tool too hard and pull the threads out of the nut. Therefore I would be VERY leery of using them for hood bolts. I only use them for <1/4" bolt sizes. I used the standard J clips for my inner fenders but attached things TO my inner fenders and firewall with nutserts.
FYI: When I used them on a Lexan windshield, there was very little tension and there was about 40 of them (10-32 stainless button head machine screws).
- 1965fordf100
