I removed the fuel tank from behind the seat today and down in the crevice between the outer skin and the bottom of the cab I found some gems and a whole lot of DIRT!!! What have you Found?
Beneath the fuel filler
Found the glove on the other side
I wish I would have taken a picture, but when I removed my generator there was a dead mouse that looked like it had gotten crushed by a cog. Aside from that I did find the original owner's manual.
Found in cas an empty beer can in the right side of the cowl blocking the drain
Uni had sparkplug in the cowl vent right side.
Right side cab corner of unis has a Ball in it can't get it ou till I cut out area to put patch in Holw there any way
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
when i cleaned out my 66 i found a husky 8m volvo tractor. made in britain. the rubber tires were gone, but the rest was there in ok shape.
100's, maybe 1000's, of spent 22 shells. They were everywhere: down the defroster, in the side vents, under the seat, in the seat, behind the tank and I even pulled one out from under that little trim piece on each side of the dash.
I did a lot of varmint shooting when I first got this truck back in the 80's. The whistle pigs (ground squirrels for those not from around here) didn't stand a chance.....
From small arsenals too extra tools for the tool box. Keep me coming, I researched the Pepsi-cola can and best I can tell is it's from the 80's. Truck originated in Oregon and low and behold that's what the top of the can said!
Found a 1"x2" cut-out of a 60's dressed playboy pin-up girl. It blew out of the lip above the drivers door when I was driving because there is no headliner. Not work safe so I'll leave it up to your imagination.
Black 1985 GT Yellow 1973 Mustang Mach 1
Black 2012 5.0 GT, 6-speed, Brembo brakes, 3.73's
Wimbledon White 1966 F-100 Shortbed, Styleside, 390, Tremec 3550, Fitech EFI
