When I say "did a brake job today" I mean one wheel.
When I bought Ruby the PO told me he had just done brakes. I thought that was cool, one less thing to do.
Three days after I got her home the brakes went out. I saw fluid on the left rear tire so I went and bought a new bottle of brake fluid and a wheel cylinder. Ive been busy and we had rain for a week so I kept putting off the repair, I just added fluid every other day.
Today was the day. I popped the wheel off, what a mess. Two broken springs, one broke shoe, and nothing was the way it should have been. I had to go to three different parts stores to get everything I needed.
It took awhile to clean everything up and figure out how things were suposed to be routed, but its all done now. I didnt bleed them, this one was so screwed up I am going to go ahead and do the other three this weekend.
Did a brake job today
- brake2..jpg (199.58 KiB) Viewed 1476 times
- brake1.jpg (225.37 KiB) Viewed 1476 times
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
Poppyred66
Re: Did a brake job today
The cylinder looks wet. If it's leaking I suggest you replace all four. Takes a couple hours unless you destroy the brake lines.
Eric
Eric
Uh, did you read my post?Poppyred66 wrote:The cylinder looks wet. If it's leaking I suggest you replace all four. Takes a couple hours unless you destroy the brake lines.
Eric
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
Rats, now the right rear is leaking. I bet the crud I cleaned off was sealing it. Off to the parts store tomorrow to buy another wheel cylinder.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
Poppyred66
Yup. Did you read mine?
Since you're going through all four wheel cylinders, I'd also inspect the two front flex hoses and the single (center) rear flex hose for any signs of aging. If the hoses didn't look like new, I'd go ahead and replace them while you're at it. How about those steel lines? I'd give them a good inspection as well. The best thing about going with all new wheel cylinders is that all the bleeders will work as they should!
Has your Slick had its master brake cylinder already upgraded to the dual reservoir style?
If not, now would also be a GREAT time to do it.
The dual reservoir system is a MUCH safer system than the OEM single reservoir unit.
By inspecting & changing any suspect flex hoses, hard line and master cylinder will provide you with more confidence that the brakes will stop you when you REALLY need them.....and not just locate the next 'weak link' in the system.
"For the price of brake parts, you can't make many body panel repairs!" <wink,wink>
Good Luck & keep us posted on your progress!
BarnieTrk
So the bottom pic with the leaking cylinder is the before.Poppyred66 wrote:Yup. Did you read mine?
The top pic with new hardware is the after.
I also stated that I planned on doing the other three as well.
Please explain why you needed to suggest that I replace the other three when I already stated that I was going to do so.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
WHAT!, is this FTE or Fordi....bmcgc wrote:So the bottom pic with the leaking cylinder is the before.Poppyred66 wrote:Yup. Did you read mine?
Poppyred66
I apologize; my mistake.
Eric
Eric
Apology accepted.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
