Vent windows? is this right or are they broke?
Anthony
Post by Anthony »
well I got my window kits from Tom at http://www.flashbackf100s.com and disassembled my drivers door this evening... the pin on the bottom of the vent window, you know, with the spring... is it suppose to be attached to the vent window frame? Mine is not and is almost rusted in two. Am I in need of new vent window frames? do I buy new or used? help me out guys so I can get these in here to reassemble the doors.. thanks...
6166 Junkyard Dog
Re: Vent windows? is this right or are they broke?
Post by 6166 Junkyard Dog »
The Bottom pivots are not repo'd Anthony be sure do one at a time since there is a lh and rh on those bottom parts....... I have spot welded for some people that bottom pivot back but it's tricky and will have to be ground back thin again since it's close where the vent rubber goes through and the outer vent frame to body of truck is close,,,,, I did hear that Carpenters has them ,, Made in China but also heard that the bottom pivots are not right and might not work,,
12649
markzieglerinsd
Post by markzieglerinsd »
I was always wondering what the difference is between the 53-55 vent window lower pivots. they sure do look the same. I have the same problem. I have tried to weld them and it has not worked. I am either going to need new pivot pin or new frame. I would like to know if the 53-55 will work as they are available.
Mark
6166 Junkyard Dog
61-66 Ford Truck only and left and right are both different on all of those trucks,,,,,,, On the Carpenters deal we sold 3 sets to the, . One pair was NOS and had to sell 3 sets since the people over in China took them apart andcould not figure out how they worked and put them together,,,,, it would be better if they had trucks over there to try these sorry made in China parts BUT HOW Many slicks you see running up and down the roads in China :?: :?: :lol: :lol: :lol:
12649
64 f100
Post by 64 f100 »
This is a common problem with these vent windows. However, used ones are not impossible to find, just pricey. Luckily, bigger trucks used the same doors and the vent windows are the same as far as I know. These show up on Ebay occasionally, and usually priced around 50$ a pair. Drivers isde is of course more in demand and will bring more money as singles. The angle of the dangle is the real problem with welding these back. The angle has to be pretty close or you might as well not have tried it at all. Won't work right. The bottom pivot is rivited on, and I believe Ford made a replacement pivot at one time. At least I've seen some come up on Evilbay, whether these were original Ford or aftermarket I can't remmember. I suggest repalcaing the whole assembly with agood set.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
