need brake brackets from a 73-79 f100 f150 maybe 250
66SouthernClassic
Post by 66SouthernClassic »
i am in the middle of finishing up power disk brakes and drop beams and i need the frame mounted brackets where the hard brake line meets and connects to the hose frome the caliper. i think i need brake brackets from a 73-79. possibly even 67-79. because the factory replacement hoses we bought arent long enough to go to the 66 mounts.
66SouthernClassic
William-in-St George
Re: need brake brackets from a 73-79 f100 f150 maybe 250
My hoses have a 4 inch or so metal line from the caliper then rubber over to the frame connection. I gently bent the metal tube part pointing it towards the frame. The frame bits and pieces are gonna have to come from the bone yard unless someone here has a set. Line lengths for these trucks vary so try a couple different years and size trucks. Worked for me.
William-in-St. George
