My 64 f100 390 FT mount-soon to be boss 292 build progress
aj64f100390-292
Post by aj64f100390-292 »
about 25 years ago my dad bought it for a work truck... when he got it the probably original 292 threw a rod loading it on the trailer, it was jacked up with leafs it as they took it to cut wood everyday. he lowered it enough that it at least would ride somewhat nice while still being able to work it. and then the spicer rear end went out and since he had never messed with spicers he decided to sell it....which he regretted as it was a posi and stuck a '76 9" with wide automatic tranny brakes and and put 2.75s in as his home made overdrive :D and after a while he started just using it to drive to work so he lowered it again so it would ride better. In the back of his mind he was thinking about fixing it up, around that time he got the alt and oil gauges out of a dump truck, and he worked at a place that powder coated lighting parts, and they let him put the cluster plate through the line-from what he remembers the standard cab cluster panel was in it when he got it' and not long after that the drivers cab mount fell...so he stuck a 2x4 in to hold up the cab...and scraped the idea of fixing it up as he really wanted a '62 unibody lwb big back glass same year as he is :D and with out asking him idk the exact timeline..he doesn't depending on the day :wink: but about roughly 98-00 he decided that after taking the heads off the 292 he stuck in it and seeing that the valves were the same size..and it just didn't like to go above 55 mph well it did but it was slow or something to that affect he said and took a 361, 391 FT bellhousing, timing chain cover and water pump...and got his hands on a .30 over cracked 390 block and used the heads from the 352 out of his '65 f100 that he used to have and built it using the best parts he had laying around he didnt have alot of money at the time. It got drove daily with the 390 for only 4 1/2 years during those I was born and he put some green 67-72 seat belts in for me, got his hands on some new pulll off 90s dodge rims for cheap as they had been sitting in this shop for a while got around to putting them on a few years later. It got to hard to keep the air out in the winter and one day he saw a beautiful purple '95 f150 xlt..the light hit the metallic flakes and he was in love with it... when he told mom he wanted a new truck and she said yes..he already had one in mind :) and the 64 got sat aside but wasn't forgotten, when he needed to use it he'd throw a battery in it and it would start right up. As one can assume around 8 years old I started taking a liking too the old ford..well truth is when I was 3 or 4 I liked it but I was so young when he parked it out back I forgot about it, before long I asked and he said ok we'll fix it up for you...I spent alot of evenings after school in the 3rd grade clean out the cab- he had axle parts in the floor' and listening to the radio :D. Mind you by this time, 14 years or so prior the drivers cab mount fell... as it was his work truck he could start anytime...when he tagged it again in '08..the floor was weaker than expected and the 2x4 started to bend the floor not long after...fast forward 4 years...there was only carpet between you and the road...we may have drove it gentle occasionally for 31/2 years or so...the weight of the cab was on the gear box so it was a you know what for dad to steer and you couldn't keep the clutch adjusted....we were out of time..it was a long 10 year wait to say the least but now I'm driving it to school...
hopefully I didn't bore anyone...just trying to explain it the best way I can with out being to long, but not leaving things out
Currently it a .30 390 with a FT bellhousing and water pump so its a bolt in deal- med rise 4bb, hv oil pump,c6 r heads , ratio rocker arms, f600 steel crank (maybe) I have one though, 4bb), -
- t18 4sp tranny
-factory look 2 speed wiper motor & delay brain box with switch with washer toggle built in. 'Stock look'
-73-76ish? turn signal unit with built in hazard switch
-power assist steering- control valve seals went bad this January right before we tagged it.. :cussing:
-ford 9" 3.25 non posi, wide automatic tranny rear brakes
AND for the record the only dent he put in it was after the '07 ice storm while cutting a tree limb..instead of falling it took the weirdest route and put a crease right in the driver side of the hood...
Image[/url]
when we first started pulling it apart- mid 2014
Image[/url]
Image[/URL]
Image[/url]
Image[/url]
Image[/url]
Image[/url]
[url=http://s32.photobucket.com/user/aj64ford/media/20160706_115941_zpsxes1dl1g.jpg.html]Image
This is how it looked for 19 years, it had a standard cab bumper with white steel headlight bezels, makes sense when you see that the bumper to grill space valance is bent on the passenger side , so one can assume it took out the bumper, and headlight bezel. around '09 we parted out a 66 and got the bezels off of it. we got this 67-72 chrome bumper off of an 87 year old man, it was under the hood of a 56 ford milk truck which by the way if anyone wants a short bed unibody he has one in a field its probably rusted pretty b bad from being in a hole but it looks like it's all there .
Image[/URL]
before we started it had no taillight bezels. drivers door trim, drivers behind hood trim, or drivers custom cab emblem ,both cab corner trim, and the passenger bed trim was side swiped hard, no door panel trim or panels, the top headliner was there but looked like crap, the corner pieces were brittle and perforated while the top wasn't. The headliner in it now is out of the 62 f600 other than the corner pieces I got those off ebay 4 months back.
Last edited by aj64f100390-292 on July 14, 2017, 11:13 am, edited 22 times in total.
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
aj64f100390-292
Re: My 64 f100 390 FT mount-soon to be boss 292 build progre
Image[/URL]
Image put the 63 f800 knobs on the 64. any tips for making these inserts whiter to match my other inserts?
Last edited by aj64f100390-292 on March 23, 2017, 5:40 pm, edited 1 time in total.
orangeRcode
Post by orangeRcode »
Outstanding post sir! :cheers:
aj64f100390-292
thanks im trying...im used to posting on FTE...so this will take me a little getting used to to say the least...takes longer :lol:
aj64f100390-292
the tach pictured is from toms broncos .com, ill be doing an in depth post on this soon...im excited to get started on the cluster...most factory looking electric tach that goes to 8k you can get! i hope to get ahold of a f800 vacuum gauge with shift light if anyone has a spare?
ive been meaning to do this build thread for months...
aj64f100390-292
the 292 may be done sooner than expected...when we parked it before we took the cab off the 390 had no blow by...well now it has super bad blow by!, we've replaced the pcv valve....
292 build specs thus far..
-ecz-g big valve '57 heads, stainless steel valves, ecg high ratio 1.7 ratio rocker arms-wouldve went roller..but people made the whole deal a mystery.. (currently in the machine shop
4 bbl tbi fuel injection with o2 sensors-eventually- penguin friendly y block- with some power!
dual exhaust
Steel crank
more specs to come we have two motors ones disassembled and thats where we got the crank...ill explain the story behind our search for a steel crank another day 8)
ill be disassembling the other one this week
-I intend to Use duraspark II HEI
-Full PCV with breather cap to air filter
Last edited by aj64f100390-292 on March 27, 2017, 1:20 pm, edited 3 times in total.
aj64f100390-292
Im wanting a clark 285 VO 5 speed overdrive out of the f800s and up for it to get more mpg, anyone got one? its that or the nv4500...
aj64f100390-292
The pic of the parted out truck is a 63 f800, were getting parts from..or started to last saterday
chris401
Post by chris401 »
aj64f100390-292 wrote:The pic of the parted out truck is a 63 f800, were getting parts from..or started to last saterday
Is the 5 speed a direct drive 5th or the Clark OD?
aj64f100390-292
I couldn't find a tag anywere on it but acording to diagrams online of the pattern its just a direct drive
chris401
Post by chris401 »
I was off. Assuming the link I paste is correct the Clark OD has 4th and 5th reversed. The Clark 265v and 267v the New Process pattern.
http://chevyc60.com/the_transmission_page.htm
bird55
Post by bird55 »
Interesting to hear you are going back to a 292. I'm a fan, myself. Yours should have a nice torque curve.
I also like the new tach from Tom's> May have to get one of those!
Not sure what you are talking about on the subject of crankshafts. All are steel. There is supposed to be a new billet stroker crankshaft being manufactured by SCAT. But it is not yet out. Your other option is a 312 crankshaft but they are getting a little harder to find. Still out there though. I have one in my 292 in my 55 TBird. Made 310 on the dyno with all the other stuff we did to it. Spendy to machine and build but everything is like that is today.
aj64f100390-292
Well the f600 292s had a forged crank not a cast- i think my terminknowlogy is right so its tougher
oldsmiley
Post by oldsmiley »
Ha, ha, right or wrong, I'm just glad to see you using it and enjoying it. There's no better feeling than to ride down the street and stop a person in his tracks, and having him point at your truck as you cruise by....... Who needs a trophy
:lol:
aj64f100390-292
Ha ha no doubt! Gotta love that lol cant wait to get back on this thread tomarrow, post some more pictures and list my mods!
aj64f100390-292
But ill get some pics of my crank, if its truely a forged crank, it will have no cuts on the back flange, completely round, this is the heavy duty truck steel crank, ive researched on the y blick sites so..if you see a big truck with a 292...check! Could get it for nothing and have a truly awsome y block part...granted will my 292 "NEED" it no...but its defiantly a cool part..we literally ended up with it on accident..ill tell that story tomarrow
bird55
Post by bird55 »
Yes, I am familiar with the forged truck crank, but they don't pop up often. I would consider offset grinding it to stroke it. haha, I love spending other peoples money! Anyway should make a good engine for ya.
BTW just where is SW Missouri. Just curious since I am in Tulsa.
Mr. Jones
Post by Mr. Jones »
AJ64,
Quick question for you.Does your F-800 have a raised roof if so what are your plans for the cab?Want to put one on my 350.....are you close to Springfield?
aj64f100390-292
Its not mine, but i didnt check, what do you mean...are you talking about the body line through the center? I can check back next time im at the yard, but i have a few items i need first...shh.. but if it does or nt once i get the odds andends i ned off a 66 ,ill be glad to tell you the location :D but as far as the cab it self goes it looked the same except for the middle of the floor pan it had no center hump, i plan on going back soon as...i found a set of original door panel clips.. :wink: im about 35 miles from springfield
Last edited by aj64f100390-292 on March 16, 2017, 9:37 pm, edited 1 time in total.
aj64f100390-292
The only other truck i had was a 62 f600...used it for the floor pans...i wish i had an account back then as...i junked the rest of the truck..but i dont even had a garage right now...so i had no place to keep it..i kept what i could...i have the doors, upper above grill valance the t98 tranny and a FEW odds and ends..
Last edited by aj64f100390-292 on March 16, 2017, 8:30 pm, edited 1 time in total.
