I broke the shaft on the clutch petal
tomrooster
Post by tomrooster »
I broke the shaft on the clutch petal in my driveway. I just made it home from a cruise night the night before . Lucky to have a spare
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Re: I broke the shaft on the clutch petal
I always am greatful for a breakdown at home
It might de a pain...
But WAY better than on the road
Anthony
Post by Anthony »
braking in the driveway is a blessing.. try it half way from wv to kansas.. lol
Doc Pepper
Post by Doc Pepper »
It'll break again. In fact, I'll bet if you look closely at it, you will see that it was repaired at least once before. What I did was buy 2 3/8" ball joints and a threaded rod at ACE hardware. Eight years later, it is still working as well as when I installed it with no wear in the ball joints. I also replaced the push rod at the bottom with a similar setup up. And because the last clutch was a heavy duty one that destroyed my steering column support bracket, I also replaced the bracket with one modified with heavy duty pivot bearing housings. I eventually replaced the heavy duty clutch (it cracked the bell housing) with a normal one (with the help of Bill W). The whole thing has been trouble free for 80,000 miles ... so far.
HydroDog
Post by HydroDog »
Doc Pepper wrote:It'll break again. In fact, I'll bet if you look closely at it, you will see that it was repaired at least once before. What I did was buy 2 3/8" ball joints and a threaded rod at ACE hardware. Eight years later, it is still working as well as when I installed it with no wear in the ball joints. I also replaced the push rod at the bottom with a similar setup up. And because the last clutch was a heavy duty one that destroyed my steering column support bracket, I also replaced the bracket with one modified with heavy duty pivot bearing housings. I eventually replaced the heavy duty clutch (it cracked the bell housing) with a normal one (with the help of Bill W). The whole thing has been trouble free for 80,000 miles ... so far.
I did the same fix last August. Can't believe how easy the clutch is now.
1965 F100
1988 F600
jamesdfo
Post by jamesdfo »
The kit from Mustang Steve's has been discussed on this forum in the past, here's a link to his site.....
https://mustangsteve.com/product/bbk/
https://mustangsteve.com/instructions-bbk-bearing-kit/
https://mustangsteve.com/bbk-tutorial/
redstone65
Post by redstone65 »
Just happened to me at work today in the parking lot when leaving for lunch. Ordered the ball joints to do this upgrade. I'll wait until late tonight (less traffic) and drive her home clutchless. This'll be interesting.
Dave
redstone65
Ended up getting 3/8-24 threaded rod and the ball joints from Napa and did the conversion. Clutch feels like brand new.
Dave
