I've placed fuel tank in frame and removed cab tank. I have bucket seats so the rear of the cab is in plain sight. Would love to see what you guys did with the "new" area if you also moved your tank. Gunna have to come up with something to hide the back wall. (I'm too old to fill with speaker boxes and sub-woofers.
How did you finish out the back of cab when tank was removed
Brian Patterson
Been a long time since I've been on slick60's and the first time w/o Facebook. Probably been 3yrs since I've had Facebook. Glad to be back!!!
Re: How did you finish out the back of cab when tank was rem
i havent did anything like that
but if i remember correctly
the later trucks that got the Ranger edition
had bucket seats , and they covered the tank
with carpet that matched the floor....
i might be wrong.. maybe somebody with more info
will chime in here
will chime in here
My grandpa had a 1975 F-100 with a pouch hung behind the seat. It was rugged like the seat cover with many storage compartments. It wasn't loose and wavy. That is what I plan to do in the 65 once I get the saddle tank installed.Brian Patterson wrote:Been a long time since I've been on slick60's and the first time w/o Facebook. Probably been 3yrs since I've had Facebook. Glad to be back!!!
I've placed fuel tank in frame and removed cab tank. I have bucket seats so the rear of the cab is in plain sight. Would love to see what you guys did with the "new" area if you also moved your tank. Gunna have to come up with something to hide the back wall. (I'm too old to fill with speaker boxes and sub-woofers.)
- FarmMotorSports
I had planned to install a Ford factory behind the seat tool/storage box. (made for 67 - 72 trucks) but it will not fit without cutting cab bracing... So nothing besides some sound deadening material is back there so far...
Guess I'll have to buy a bump side for my storage box...
61 F250 Unibody
& 4WD
& 4WD
Brian Patterson
- Alan Mclennan
I put carpet on the back of the cab, stuck it to thin MDF for support. took it up to the rear window height and tucked it under the seal.... don't remember how to post pic's at the moment !
Brian Patterson
I looked at your gallery Alan and saw the carpet. Looks good. You have a beautiful truck!!
- Alan Mclennan
Thanks Brian
tomrooster
I went to Walmart and bought a cheap black carpet . I insulated first then glued and screwed the carpet in place. sorry no pictures of that part
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
go to google and enter 64 F100 interior. hundreds of shots of different interiors you can get good ideas .
Bill: shasta lake ca. 1966 F100
