tranny.....
az63pu
tranny.....
Post by az63pu »
got a chance to pick up a borg warner tranny wanted to know if the price was right says its a three speed with overdrive he's askin' 250.00 for itits out of a 66-71 i think he wrote. i'm gettin it for my 63 223 goint to the four speed i got in there now, got that granny gear.
mark
az63pu
Post by az63pu »
.....my book here says it a Warner T85N 3-speed with overdrive , the question is will it bolt up to a 223 motor, says its got a few wires and an overdrive cable. thanks for any input....mark
Garbz
Post by Garbz »
Make sure it has the dual pattern to fit the early bell, Pre 65 has a smaller pattern and input shaft. And it needs a bunch of ancillary parts to make it work. If it is a 66 to 72 it is a three speed OD not a four speed. Has electrical switches, selonoid, wiring harness and a pull cable to cativate it. These also shifted by the three on the tree, so you will need a new wonder indy floor shifter.....And 250.00 Is real steep for a 75 buck transmission.
Outlawed in 73.......As it can be in gear with the engine off and will roll if in OD....Ralph Nader at work.
Garbz
