brake rotors
brake rotors
I have a 66 f100 short bed that has been converted to front disc brakes. The rotors have a 5x5.5 bolt pattern. Any one found rotors that bolt on with a 5x4.5 bolt pattern
- Alan Mclennan
No ! But
to our little club!
Alan,
Alan,
I'm sure CPP, ECI or Master Power has them. You also may be able to just have the stock rotors redrilled.
Truckfarmer2
1980-1983 Ford made a light duty truck they designated as a F100. There weren't very many of them out there. It used the 4 1/2" bolt pattern. Those trucks use the same bearings as the 73-79 F100/F150. I do not Know if the spacing front to back is the same.
Let us know what you find....
