Radio Delete
Radio Delete
was there a cover for the dash holes for the radio delete option or were there simply no holes there?
- Johnny Canuck
don luster
My observation on slicks is the ones that didnot come with radio the dash was solid without a cover. I have observed a few covers that go over opening. I will make a guess that you could maybe order it both ways. I not sure but many were dealer had to cut the the opening for a radio that was dealer intalled. I believe that the factory made a cover for the opening or they appear to be factory made. Maybe someone more informed about this will add their knowledge for all of us
- 66fordtrucknut
- Gary Seymour
- ezernut9mm
if someone could find a 67 radio delete cover maybe they could try that to see what it would look like covering the holes.
not in my 61
- ezernut9mm
i don't think the radio delete trucks had the speaker hole either.
- 66fordtrucknut
don luster
fmartin_gila
semotrucker
this is the "cutout" (its just holes) ' for factory radio.Gary Seymour wrote:My dash has cut outs for a radio, but no radio. I can't tell if it's factory or PO. It's almost cut too well to be a PO. It has a non original antenna.
61 uni no radio
Brian -- on that pic of a factory cut - -it looks like there is an outline of the radio on the dash. Like it was indented a little.
Or is that just some dirt.
My 65 has a radio and the install is very clean, no metal burrs or shavings. No indent. But my Dad says it did NOT have a radio from factory, but instead the radio was installed by the local dealer.
If that's true (Dad's not 100% anymore), then the dealer did a helluva nice job in 65......
cdherman wrote:Brian -- on that pic of a factory cut - -it looks like there is an outline of the radio on the dash. Like it was indented a little.
likely the dealer had a special pre- made plate ftom Ford to get all the holes correct.
blackagatha
man... my dash is a MESS!
HACKed out radio hole- moron drilled his holes for the jigsaw OUTSIDE the line, Cut it crooked, cut it about 3/4 too wide and pop riveted in some chunk of poopy, wtf.
"speaker hole" in the dash looks more like an attempt to remove the soul of the truck, looks like they made it with a can opener and a hatchet
didnt murder the door plates, but I would rather they had than rip that awful hole in the dash.
and there's random holes drilled all over the dash- 2 in top and 2 in bottom of instrument panel, and 3-4 in the region under it.... gaa!
