It`s smoking time!
It`s smoking time!
I have decided to have a go at building a smoker/BBq!, so has anyone got any tips or photos of their creations, I`m planning it around a 100ltr auto LPG tank (about 25 gal), and any tips on not blowing yourself up cutting LPG tanks? :(
F7BIGJOB
Post by F7BIGJOB »
Pull your valve, fill with water, opening up, let sit a bit, run flame across top, keeping it full with water, you should be alset.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
jamesdfo
Post by jamesdfo »
Alan: a quick google search for "DIY smoker" got About 2,320,000 results:)
here is a shortened up version of the url for the search
http://tinyurl.com/727yymx
Next summer, when I dig out the roots from a Mountain ash we cut down over christmas 2009, I am going to dig down so that I can do like the bedouins do, and cook a lamb underground (dish is called Zarb?)
saw this on a canadian cooking show, Chef Abroad, with chef Michael Smith, they went out into the Jordaniandesert near Wadi Rum, where they cooked a whole lamb underground:)
Post by rickairmedic »
Alan lots of good folks on this web site . Also ALOT of Texans who take pride in their grills/smokers :D.
http://www.shopfloortalk.com/forums/index.php
unibody madness
Post by unibody madness »
Allen,
I made a smoker stacking two 35 gallon recovery drums together,
I used a primus camping stove as a heat source and an upper door for the meat, sausage and such with a large bowl under the meat. A lower door for adding the smoke material in a cast iron frying pan above the flame.
I also added a small fan at the top of the drum to equalize the smoke and heat.... has been working for 15 years.
I will tell you it creates its own weather inside and is susceptible to outside temps, so some kind of insulation will help a great deal
as to the cutting of your tank, water, is the only way I know to cut a pre used tank like f7bigjob suggested
John
Hunter's 64
Post by Hunter's 64 »
BMJ's 65
Post by BMJ's 65 »
Alan,
Here is a thread to my brother and I's build.
http://www.smoked-meat.com/forum/showthread.php?t=16913
Since this build thread we've cooked on it a few times with very good results. Some of the advise I can offer up is find a vessle with as thick of steel as possible. The tank we started with was pretty thin and liked to move around on us when cutting and welding. Also, if your going to do an offset fire box, make sure to err on the large side. I've found it easier to have a big bed of coals/logs and choke them down to the temp I'm shooting for rather than having to continually add.
Here is one more thread that shows the pit in action,,,,,,, Hell, there's even a couple trucks in there.
http://www.smoked-meat.com/forum/showthread.php?t=17906
What's in the garage at any given moment?
FE powered Bump
93 Lightning
66 Slick strewn all over the place
08 Taurus
13" Huffy W/ training wheels
stronger66ratfink
Post by stronger66ratfink »
Got to go with a Oklahoma Joe pit and mesquite for that good Texas barbecue flavor and brisket
Steve, I think I`ll got your method!, being a gas fitter I have seen what something like this can do! :oops:
James, look up "Hungi"!, it`s the New Zealand way of cooking, and is very similar to what you are thinking of.
Rick, I have put that on my favourites list.
Johm, I`d like to see your smoker!
Danny, that is the design I think I will go with!, with the bit of Googling I have done that one seems to work the best! and have added that to my fav list as well!
Matt, What can I say mate!, that thing is awsome! 8)
, and I think you had better bring it to SS5 with! OR!, don`t show up!!! :lol:
I think I may join that site you are on, there is some great info to be had, thanks for the link!
Mikey, I think thats the restaurant Ezer wants to take us to next year before SS5 starts!, we did however go to Soulmans BBQ joint while we were in Mesquite TX!, that was really full on smoked ribbs! only thing missing was Beer! :cry:
Well don`t let the grass grow under your feet!, just came inside after playing with the new toy!, I think it`s 140 litre tank and it came out of a dent! 8) and it weights a ton!, her`s some pic`s, the transit van comes in handy!
just hook and lift
I modified my axle housing trolley to be a temp stand for the tank
tank comp plate!
BMJ's 65
Post by BMJ's 65 »
That tank should be perfect for smoker! Have fun with it. We are building the trailor for ours in the next couple weeks, sure would be fun to drag it down to SS.
FE powered Bump
93 Lightning
08 Taurus
fire truck
Post by fire truck »
That sounds like a great idea.
Kid
Re: It`s smoking time!
Post by Kid »
I am going to check out these links as I am wanting to build one on a trailer myself. I am looking for a couple water tanks off a Cement truck for mine, they should be pretty thick and work out well. I have the axle and frame material so now all I ned to do is find the tanks and get started...............Kid
BMJ's 65
Post by BMJ's 65 »
Kid, that web site from the links I posted is a good one. I've learned quite a bit from those guys and girls.
FE powered Bump
93 Lightning
08 Taurus
Darrell, that site that Matt mentioned is a great site!, in my surfing I found this one as well!
http://smokerbuilder.com/forums/viewtop ... 0&start=10
Smoke um if your got um! :twisted:
A couple of pic`s of my progress
And Yes!, that is a boot on my foot! :mrgreen:
these things are great for picking up metal swarf!
OK!, I thought I`d give a photo up date of my progress with the smoker, I`ve named it "IRON FIRE", because of the flame I made for the chimney out of horse shoes! :burp:
the fire box,
fire box dampner,
Fire box door,
start of the firebox air intake,
The air intake needed an adjuster, so I cut this off an old plow in our front yard,
after abit of cut and shut this is what I ended up with
joining the firebox to the cook chamber,
with the chimney cut in and welded,
took it out for its first burn!,
a pic of how it got it`s name!,
BMJ's 65
Post by BMJ's 65 »
Alan, that thing turned out awsome! I especially like the details like the vent adjuster and the low rain cap adjuster. The horse shoe flame is cool as hell. Your gonna have some good eats from that unit 8)
FE powered Bump
93 Lightning
08 Taurus
fire truck
That is AWESOME dude!!!
fire truck wrote:That is AWESOME dude!!!
x2. whens dinner?
