However I need to get an adapter & from what I've found I can simply use a Grant adapter, but I am not sure what year my column/steering wheel the PO retrofitted, its obviously mid-late 70's wheel & collar but I dont know how much of a visible physical/mechanical difference there is with a (non tilt) column from 66 to 79, I am wondering if the 3285 Installation kit will work, or if it would be at least close enough to modify to work?
example: http://www.streetperformance.com/part/g ... -3285.html
