Rear sump oil pan in a 66
66camperspecial
Since the 460 that is in my 66 right now has issues I will most likely got with a 302 or 351-W and since I will most likely find one in a van or 80 and newer truck it will have a rear sump pan so will it work or have to convert to front sump pan.
Re: Rear sump oil pan in a 66
I have a 66 that I am going to put a 351W in also. I have the engine rebuilt and setting on the stand. When I was putting it together I put a front sump pickup and pan on it, but when I started measuring things it just didn't seem right so I switched to a rear sump. I'm hoping my measurements were right so I don't have to switch back to a front sump. I'm sure somebody out there has done this engine swap and can say for sure which is right.
orangeRcode
Subscribing. Have a 65 long bed I'm planning on going with a 302/auto transplant once I find a donor.
tomrooster
I have a 65 f100 with a 302 front sump and from the pictures I have it looks like rear sump will work. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
Using a rear sump truck pan on the 351W in my 65 no clearance issues at all.
64 Ranchero (has new owner)
65 F100 shortbed
66 Mustang (A code 289)
67 Bronco
65 F100 shortbed
67 Bronco
