Rear sump oil pan in a 66
66camperspecial
Post by 66camperspecial »
Since the 460 that is in my 66 right now has issues I will most likely got with a 302 or 351-W and since I will most likely find one in a van or 80 and newer truck it will have a rear sump pan so will it work or have to convert to front sump pan.
Re: Rear sump oil pan in a 66
I have a 66 that I am going to put a 351W in also. I have the engine rebuilt and setting on the stand. When I was putting it together I put a front sump pickup and pan on it, but when I started measuring things it just didn't seem right so I switched to a rear sump. I'm hoping my measurements were right so I don't have to switch back to a front sump. I'm sure somebody out there has done this engine swap and can say for sure which is right.
orangeRcode
Post by orangeRcode »
Subscribing. Have a 65 long bed I'm planning on going with a 302/auto transplant once I find a donor.
tomrooster
Post by tomrooster »
I have a 65 f100 with a 302 front sump and from the pictures I have it looks like rear sump will work. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
ponypoor
Post by ponypoor »
Using a rear sump truck pan on the 351W in my 65 no clearance issues at all.
64 Ranchero (has new owner)
65 F100 shortbed
66 Mustang (A code 289)
67 Bronco
