Headlights Flash
leftside11
Headlights Flash
Post by leftside11 »
newest owner of 65 long bed
headlights begin to flash on and off after being on for a few minutes. also when the high beams are clicked the dash goes black.
still learning my way around the truck. any suggestions appreciated.
this is a great site
thanks,
lefty
Max
Post by Max »
My first thought would be a grounding issue. I'd check that real good first.
i think the switch is bad.
this tells the story
http://fordtruk.com/index41.html
leftside11
thanks for reply
which switch do you think? headlight or dimmer?
brojohnak
Post by brojohnak »
headlite switch you can order one from LMC truck catolog on line
63 F350 dually wrecker
64 F250 4x4 Great White
66 F100 lwb daily driver
66 F100 4x4 Xmas truck
plus 4 parts trucks
supersmitty
Post by supersmitty »
check your headlamp bulbs also. The same thing happened to my 65 and one of the filaments in the driver side bulb broke and shorted out that light causing them to go on and off when you went over bumps.
61 Merc
Post by 61 Merc »
I would first of all check the grounds, then check all connections. The switch is also notorious for creating problems, best thing to do if you are replacing with a new switch is to also go with the headlight relay and reduce the current going throught the switch. The relay kit is available from LMC also.
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
Dave Rogers
Post by Dave Rogers »
The dimmer gets pretty beat up too. It caused mine to work intermitantly.
DAVE
Lowell
Post by Lowell »
Blinking headlights are common on slicks.Best thing to do is like Dean said . I added relays to mine and the problem was gone.
Ford blue blood
Post by Ford blue blood »
Might check and see if there is a circuit breaker on the switch. They will auto reset making your head lights flash on and off.
Many great Fords,
fought with that for so many years before reading the article on the relays,but never had a prob since i started using them.
Fordman
Post by Fordman »
yes the headlight switches have circut breakers in them and will pop on and off as they heat up and cool down. possibly a bd dimmer switch if it only does it on high beams. but it could be the headlight switch.
