Oil Pan
Oil Pan
GOD BLESS & ROLL TIDE!
find a spot that is 'low' to get the most oil drained out, in a 'convenient' spot to get to
i would braze it in , but that is just me... my
Or you could "notch" the Volare subframe to give you clearance - if the cut leaves a gap just weld a piece of 16 ga in there to close it up.
"Back when" the Volare subframe was "the" IFS upgrade for these old trucks.
- Alan Mclennan
I agree with that agreeance!, or change the sump to the opposite to what you have!slick4x4 wrote:![]()
All the above ideas will get the job done.
If you are determined to change pans without bucking up for an aftermarket pan such as Milodon, CANTON, etc, the 351M/400M pan/pickup is a direct bolt-on, you just need to look at the various cars & trucks they came in and see if one of them is better suited than your cleavland pan.
The 351/400M's were used in full size ford/mercury/lincoln passenger cars, as well as dentside/disco dentside 2WD & 4WD pickups....
****remember, if you change oil pans, you need to change the oil pump pickup as well!!
James
James
- Gary Seymour
Thanks for all the info guys but I came across a deal for a Milodon pan. It's got a 6 1/2" front sump, 4 5/8 thru the middle, and 8 1/4 rear sump. Both sumps have drain plugs. Alas as I was taking the exhaust off I noticed were some water had been leaking out from the head gasket. So what I had hoped to be just cleaning and painting and reinstalling has now turned into a complete rebuild. Once I looked in it I saw somethings I didn't like so I figured since I already had it out I might as well fixed and not have to worry about it later. Good thing I didn't buy that other truck. By the way has anyone had any dealings with the Sanderson headers?
