1964 3 speed gearbox, need oil seals
The Bird
Post by The Bird »
Does anyone know where I can buy an oil seal kit for the 1964 F100 3 speed gearbox?
winr
Post by winr »
Hey The Bird.
I bought a gasket set for my 1965 3 speed 3.03 top loader.
Does your trans have a tin plate on top or a plate on the drivers side with the shift levers ??
Ricky.
All your Slicks are belong to us
The Bird
Post by The Bird »
Shift levers on the drivers side
The Bird
Post by The Bird »
I have oil leaking from both shift lever shafts and the rear of the trans where the driveline connects. The truck has been sitting for 10 years+ and I think the seals are dried out and need replaced. I looked for a kit to replace all the trans seals and so far I havent found anything.
winr
Post by winr »
The Bird
Post by The Bird »
Exactly!
64 f100
Post by 64 f100 »
Front and rear seals should be available from your local parts store, and the shift fork seals are o-rings I believe.
The Bird
Post by The Bird »
Thanks, I'll try that.
