Any one parting out a 66
walts 66
Post by walts 66 »
I can sure use a clutch & brake peddle assembly. Mine is so bad, I put new bushings in and that did't do a thing. Mine is the type that does not have a return spring at the peddle . It's under the cab. I don't know if that matters or not. Tks.
66 Short Bed 240 T-18 Dana 60-2
96 Sportster
there is a big return spring for the clutch if you look up into the pedal/ bracket area you can see it
the ends of the linkage and the holes for the linkage and the places for the bellcrank bushings and the ball ends get so sloppy that when you add up all the slack its hard to adjust.
a lot of the ones i have found are unusable. some could be repaired by welding a steel bushing in the hole and then machining to the factory size.
i think some of the parts sources offer new bellcranks and ball ends.
walts 66
Post by walts 66 »
I looked for a spring a number of times and there is none. there is not even a plate to mount the spring to on the clutch arm
96 Sportster
